unconfigure radius server
unconfigure radius {dynamic-authorization [server index]
Description
This command removes the RADIUS server configuration for a given server. Having index be in its own setting is done to remove the possibility to set the mgmt-access or netlogin setting prior to index.
Syntax Description
server RADIUS server.
index RADIUS server index.
dynamic-authorization Specifies dynamic-authorization.
Default
N/A.
Usage Guidelines
None.
This command was first available in ExtremeXOS 16.1.
The dynamic-authorization keyword was added in ExtremeXOS 22.1.
Platform Availability
